7 members (68ironhead, Bill Hanlon, Joe H, Chris's 46 / 515, Pre '68 Dave, pauld, 1 invisible),
52
Mod | | | Forums66 Topics128,185 Posts1,057,279 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 9 New Guy | | New Guy Joined: Sep 2011 Posts: 9 | heres the thing. i enjoy listening to tunes when i drive and im coming up on installing a radio in my 41 1/2 ton. the cab is so small in this thing and i refuse to do any chopping of metal what so ever to fit the speakers in (trying to keep her clean and origial you know). im just wondering what the art deco era guys have done to mount speakers in their truck without chopping the old gals up.
1941 chevy 1/2 ton
| | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | I just made kick panels out of 1/4" plywood and cut holes for 6" speakers in those. One thought I had was somewhere under or behind seats, depending on your seat/tank situation. My tank's out back under the bed so that was an option, if you're still stock that won't be an option. Last option was to mount facing downwards under the dash, out of sight.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Like Green farmer said. Kickpanels, and under dash. I thought about the rear cab corners but then they are blasting in your ears ! Might be able to squeeze a few into the gas tank / seat box area. Not sure I like the thought of electricty in that closed space tho *g* | | | | | Joined: Sep 2011 Posts: 9 New Guy | | New Guy Joined: Sep 2011 Posts: 9 | i really like the kick panel idea. i bought cardboard replacement ones but i may reinforce those with some 1/4 or 3/16 plywood and cut holes for some 6" speakers. thanks guys
1941 chevy 1/2 ton
| | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | I had the same dilemma but opted to cut the lower sheet metal at the corners to install mine. They're not so high that they would blast in your ear or so low they would be muffled. | | | | | Joined: May 2007 Posts: 39 New Guy | | New Guy Joined: May 2007 Posts: 39 | I had the same issue, didnt want to cut up the dash or have a modern look. So for the radio and front speakers I built them into an old ford 3 door heater box. I also have the a/c vents built into the box. It will bolt onto the center of the firewall I had to tear apart the heater and modifed it quite a bit. For my rear speakers I had to replace the sheetmetal on the back of the cab from the belt line down. When I did that I added some extra vertical stiffeners back there. I was able to use those to with added horizontal brackets to mount some narrow speaker boxes behind the seat. I added pics of these things in my photo album http://s1233.photobucket.com/albums/ff392/thirtyniner39/
39 chevy 1/2 ton 48 chevy fleetline aerosedan
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i got abs kick panels and speaker pods from this place http://www.roddoors.com/ for my 40. but as i see they went out of business. they are pretty slick and make for a nice clean looking job. | | | | | Joined: Mar 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 66 | There is also the option of under-the-seat speakers. Apparently they are woofer/tweeters. Woofers you feel in the seat of your pants and the tweeters face out below your legs. Have not heard them yet, but I've been told they sound good. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | This is where I mounted mine. Speakers
~Jim
