2 members (BC59, Uncles51),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,481 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I'm not sure if this is the right forum to post this on, but here goes:
I have the original (1950) heater shutoff valve. It goes through the firewall and has two tubes that connect to the incoming heater hose for the heater core. Inside the cab is a knob under the dash that says "warmer" with coresponding arrows.
What has me stumped is the wire or tube coming out of the unit. It looks like it might be a thermometer tube, but for what purpose? Does it open the valve if the heater gets too hot? And what does the loose end connect to? Does it just sit there and monitor ambient air temperature?
Thanks in advance for your help!
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Here is how to attach it ...link... Others can address its purpose and function. Try searching Ranco valve | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | Thanks Dads50! The pictures and the link sure help. From them I figure the capillary tube fine tunes the opening of the heater valve depending on the ambient temperature in the cab.
Is there any way to test the capillary tube for proper functioning?
Craig
CK
| | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Word on the street is to use your freezer and a pan of hot (±130°) water. Allow a 5 - 10 minute temp soak, then watch how it affects the plunger.
Don't expect "climate control" results. Be glad that you have the cap tube. I know of no place that replaces those that are missing, judging by forum posts.
When I dug into my heater control valve guts, I noticed that the plunger stroke is hardly enough to shut off the flow through the valve...and this is independent of the capillary tube.
Bill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The pictures and the link sure help. The second link posted is courtesy of tclederman. He originally posted the oldcarmanual project page. Very helpful Here is another discussion on the tube https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=709231&page=1Back in the 70's when my Dad was driving the 50, the heater always worked when we needed it. The tube had been missing from the valve for years. Sounds like the test method suggested above should work. Good Luck | | | | | Joined: Aug 2008 Posts: 28 New Guy | | New Guy Joined: Aug 2008 Posts: 28 | My Dad's 52 is also missing the control tube/valve with capillary tube - Apparently now I know it heater was always on with coolant recirculating through the heater core. Thanks to all for the pics and references.
Your not trying hard enough if you don�t screw up every once in a while.
52 1/2Ton 235 | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | About ten years ago, I picked up a valve at a junk yard. I sent it off to Chevy Duty (now Classic Parts) to have it rebuilt. I had no idea there was supposed to be a capillary tube until they called to tell me that it was missing. They were able to reattach one and fix it up quite nicely. I don't know if they still offer this service, though.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
