1 members (parklane410), 73 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
Since I have electric wipers, can I use that vacuum port on the back of my Offy intake for the distributor and just plug the ones on the carbs? If not, then could you explain why so I'll know?
OUP
"when I grow up - please go ahead and dig my grave!"
You need the "ported" vacuum from one of the carbs for the dizzy, not manifold vacuum. I'm sure someone with more knowledge will tell us the difference, all I know is that the are not the same.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
read this - ported vacuum was the first attempt at emissions control
Thanks Squeeze, even I can understand that.
I appreciate it,
OUP
