5 members (klhansen, TooMany2count, Wally / Montana, Gray_Ghost, 1 invisible), 145 guests, and 1 robot.
Topics128,051
Posts1,055,711
#798897 11/18/2011 5:57 AM
What would be the fuse size for the heater on a 54 3100 6 Volt motor ?
Thanks again...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
healingbear #798901 11/18/2011 6:02 AM
I use a 20amp, same as my other fuses. Maybe one day I'll burn up though?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #799217 11/19/2011 6:03 PM
Thanks Mr. Lang...
I am having to rewire from the motor to the power source because the original wire was gone...
I do not remember seeing a amp # on the motor when I cleaned it up... The 1929 - 1957 Chevrolet Master Parts & Accessories Catalog does not say anything about what specific size ( Amp. ) it used for the motor... All though the do have a list of fuses with part #'s, amps and lengths of the fuses but no mention as to where they go...
healingbear #799935 11/22/2011 12:20 PM
I am not sure about a '54 but all the earlier models had the fuse on the back side of the switch that was mounted on the underside of the dash.
Huck #799992 11/22/2011 4:27 PM
The fuse on the back of an NOS under dash switch I purchased is 14a
...pic...
Someone may have placed an incorrect fuse in the holder, but that's what's there
Good luck
DADS50 #800269 11/23/2011 9:16 AM
Thanks again Gus...
I wired the fuse from the power source ( ignition switch ) to the new heater switch... I did it this way because the old heater switch showed signs of overheating ( melted looking )... That is why I needed to know the correct size fuse...
healingbear #800370 11/23/2011 5:51 PM
Fuses are rated to protect the size of wire that's being used. If the 14 amp fuse is correct, that's intended for approximately a #12 wire. You would need to measure the current draw of the motor in question, and add about a 50% overload capacity to the fuse, then use the right size wire to carry the current draw. The whole concept of a fuse is to interrupt the circuit before the wire can overheat to the point of damage. For instance, a 20 amp fuse on a #18 wire would allow a current flow sufficient to melt the insulation before the fuse would fail. A #18 wire works best with about a 7.5 amp fuse, maybe 10 amps max. As the accessory load and the wire size increases, the fuse size goes up to match it.
Edit: Dirty switch contacts or loose connections can result in localized overheating and damage, even if the wire and fuse size is correct.
Thanks Jerry,
You are right about the dirt, it did see its fair share of very dusty roads...
Hotrod Lincoln #800839 11/25/2011 10:16 PM
Jerry said
"You would need to measure the current draw of the motor in question, and add about a 50% overload capacity to the fuse, then use the right size wire to carry the current draw".
Jerry is 100% correct - so correct this should be posted as a standard reply. On a small motor ie truck heater motor I go along with the 150% to allow for startng current since in many truck cases teh fuse has a multiple role ie fault current, motor starting current and motor overload protection.
Dan Bentler
