7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible), 125 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#799833 11/22/2011 1:36 AM
1 Offline
I just bought a 1949 3/4 ton chevy pick up and now can't get the hood to open. I've tried the release on the right hand side, with no luck. Any suggestions? Thanks.
123456 #799845 11/22/2011 2:07 AM
Try spraying some penetrant from the under side.
Cletis #799853 11/22/2011 2:35 AM
Try pushing down on the hood while pulling on the release. It's a 2 stage latch: first release with long handle on right then pull up on latch in the center. http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm1101.htm.
Ed
Forty9 #800793 11/25/2011 2:59 PM
There was a post a while ago regarding this problem. They ended up pushing in or back towards the cab on the nose of the hood and also pushing it to the side.
1951 1 Ton Completed
I think your answer is in this 1948-1951 Chevrolet Truck Shop Service Manual.
Under Chassis Sheet Metal, chap 11, pages 3-4. Pay special attention to page 4, Lower Catch Plate:-adjustment-par 2.
You may have to take a small screwdriver or wedge thru the grill opening and push the
lock bolt one way or another while holding the latch in the open position.
Once you get it open you should make the adjustment outlined in the manual.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm1103.htm
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm1104.htm
If you can’t get the lower catch plate to center on the lock bolt then the upper catch plate
may be bent. I use a short length of threaded rod and a lock nut in the weld nut of the
upper plate and tap it back in alignment with a soft hammer, then you can adjust the
lower plate according to the manual.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
