9 members (farmallb, JW51, Barney1951, klhansen, Bill Hanlon, Otto Skorzeny, 1955 1 Series, sron48, 1 invisible),
87
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,487 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,752 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,752 | Glad it's working now, but when, not if it starts to leak again, you need to find yourself a real machinist. Look for somebody with a "Blockmaster" milling machine and an operator who knows how to use it. I would usually take .010" passes off a head or a manifold, and the entire job should take about one hour or less, after a relatively simple setup procedure. I could see a concern with heat buildup if a belt sander type head surfacer was being used, but a mill is a different can of worms. Jerry
