| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Hello!
I've gotten almost everything in the Apache working except the dome light. I pried the cover off and plulled the mounting plate only to find that there was about 2" of wire, one strand white, the other black with a white stripe, hanging from the socket with two big wads of dried out electrical tape attached. I reached in the hole as far as I could, but I couldn't feel any other wire.
How is the dome light wiring routed from the light switch throught the cab to the inner roof panel at the back of the cab?
The manual shows that a white and orange wire feed the dome light, not a white and black w/white stripe like on my light. Could there have been a change in wire color or ?
Thanks..
Chris | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the wires go behind the edge of the inner panel, over the drivers door and down the drivers A pillar to the switch - if you can get past the headliner with a hooked piece of stiff wire you may be able to fish the original wires out ... the white wire goes to the gr(oun)d terminal of the light switch, the orange goes to the D(ome) terminal and is hot all the time, turning the knob gives the ground to the socket, which should be insulated from the cab/light base at the light .... as to the black wire with white runner, the light socket on yours may have been changed at some time as indicated by the splice tape
Bill | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Straiten out a clothes hanger (the old kind that a strong wind won't bend over. Put a small loop on one end. You have two areas to pull the wires, from the dash to the top of the window post and from the door post to the dome hole. Good luck and keep the profanities down. nono
~Jim
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | bring a snack and a couple of beers - it took me nearly three hours to pull new dome lite wires on my 56... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | But a satisfying job, time well spent.
~Jim
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | I took the headliner out, it made it easier. But getting that &@^# headliner trim back on was a beach.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
