7 members (msmall, Otto Skorzeny, Phak1, 55shaker, TUTS 59, Wayne67vert, 1 invisible),
106
Mod | | | Forums66 Topics128,095 Posts1,056,069 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 78 | I'm building a 1953 3100 truck and having trouble with mounting the original steering wheel. My shop manual says I am missing the hub cover assembly which mounts between the steering wheel and the steering column. Does anyone know where I can get that part? None of the part vendors I have checked carry it. Any suggestions?
1953 3100 Chevy 5 window 1971 Chevelle SS
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 |
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Do you have a part number for the "hub cover assembly" Dose your mast look like this? ...pic... | | | | | Joined: Sep 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 78 |
| | | | | Joined: Sep 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 78 | Also, I noticed that you didn't have one on yours. On pic #22 I noticed there is a gap between your steering wheel and the column. That is what has me confused. I thought there was a collar to hide that gap which is what I thought the hub cover assy covered on your pic # 17. What is correct? Thanks.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | That page of the assembly manual is for a 54. I don't think that hub is used on a 53.
The gap in the pic is there because the nut is not installed yet.
Sorry for the confusion. I added the factory assembly manual pic in that folder for a member who has a 54
Maybe someone with a 53 can confirm | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1954 was the first year for built-in turn signals in trucks. If the truck was not ordered with turn signals it got the "cover assembly" in pic. If turn signals were ordered there would be a switch mounted to the top of the column filling this space. Up through 1953 the steering wheel just comes down close to the top of the column, that's all.
See the USA in your vintage Chevrolet! My Blog | | |
