7 members (KEVINSKI, Otto Skorzeny, Tronman, Charles in CA, Goach2, 66flea, 1 invisible), 233 guests, and 3 robots.
Topics128,257
Posts1,058,015
Members48,479
1 Offline
I'm building a 1953 3100 truck and having trouble with mounting the original steering wheel. My shop manual says I am missing the hub cover assembly which mounts between the steering wheel and the steering column. Does anyone know where I can get that part? None of the part vendors I have checked carry it. Any suggestions?
1953 3100 Chevy 5 window
1971 Chevelle SS
I sent you a PM. Fred
Do you have a part number for the "hub cover assembly"
Dose your mast look like this? ...pic...
1 Offline
Yes, it does. The p/n is 3701357 Hub Cover Assy.
Here is a picture of it
https://picasaweb.google.com/103098517476416596131/UntitledAlbum12#5566157541409395810
1971 Chevelle SS
1 Offline
Also, I noticed that you didn't have one on yours. On pic #22 I noticed there is a gap between your steering wheel and the column. That is what has me confused. I thought there was a collar to hide that gap which is what I thought the hub cover assy covered on your pic # 17. What is correct? Thanks.
1971 Chevelle SS
That page of the assembly manual is for a 54. I don't think that hub is used on a 53.
The gap in the pic is there because the nut is not installed yet.
Sorry for the confusion. I added the factory assembly manual pic in that folder for a member who has a 54
Maybe someone with a 53 can confirm
1954 was the first year for built-in turn signals in trucks.
If the truck was not ordered with turn signals it got the "cover assembly" in pic.
If turn signals were ordered there would be a switch mounted to the top of the column filling this space.
Up through 1953 the steering wheel just comes down close to the top of the column, that's all.
My Blog
