| | | Forums66 Topics128,021 Posts1,055,372 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 144 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 144 | The steering gearbox/column is out of the truck. There were no issues with the steering so I don't plan to open up the gearbox but I would like to change the lube. I've got it draining right now and man is it thick. Would it hurt any seals, etc. to put some solvent in the box to clean it out? I would then fill it with new lube and drain once or twice to make sure the solvent is out. Another thought is just to heat it to thin the lube.
Dave www.fallenherosdreamride.orgall give some MY SON GAVE ALL The fallen hero's dream ride is a 1951 Chevrolet 3100 with original 216 In memory of LCpl Phillip Vinnedge USMC KIA 10/13/2010 Afghanistan
| | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | I just did mine. I used mineral spirits in mine. Got it pretty clean. I used John Deer corn head greese in mine. It's what every one in this site said to use. So far so good. | | | | | Joined: Jan 2011 Posts: 144 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 144 |
