2 members (Bill Hanlon, Nuts&Bolts), 40 guests, and 3 robots.
Topics128,014
Posts1,055,324
Members48,419
#799203 11/19/2011 4:19 PM
My 66 step side C 10 is to rusted for me to fix but I found a truck that might be a perfect donor but I am not familiar with a C/K 1500 is that the same as my truck but only a 3/4 ton and will the cab and the doors go on my truck and the fenders. The donor is a long bed but I don't need any of the back of the truck I think I can repair the back end of my truck fenders and everything look pretty good.
Thanks for the help and suggestions.
climberman #799438 11/20/2011 5:08 PM
The series designations for the 1/2 ton (C10 or K10) and 3/4 ton (C20 or K20) are used in the '62-'66 Chevy trucks, Apache for the earlier '60 & '61 Chevy trucks. What year is the C/K 1500 truck you are considering for a donor? Although it is possible to transplant a later model cab onto your '66 Chevy C10 chassis, it is more costly and time-consuming, due to the modifications needed at the frame-to-cab perches, etc. Also, the overall value of the truck is diminished on the backend, if you decide to sell.
The C10, K10, C20, K20 & C30 cabs of the same years ('60-'60, '61-'61, '62-'62, '63-'63, '64-'64, '65-'65 & '66-'66) are directly interchangeable. The 3/4 ton & 1 ton rear frame-to-cab perches are the vulcanized rubber style, which are different than the cantilevered style found on the 1/2 ton models.
FYI, here is a great article on the Chevy trucks:
History of the Chevrolet/GMC Trucks
