4 members (Joe H, Gdads51, jmoore, 3100RustyParts), 86 guests, and 3 robots.
Topics128,264
Posts1,058,350
Members48,485
#79896 07/11/2007 3:16 PM
I just had a quick question regarding how to turn the crankshaft on my 283 as I put it together. Is there a socket I can buy to do this?
what is the best method for this?
GSova
GS
#79897 07/11/2007 7:42 PM
There's a socket listed in the Comp Cams catalog that's designed for turning the crank while degreeing the cam. If you don't want to invest in that one, jus thread a 7/16" fine thread bolt into every other hole in the crankshaft flange, and use a pry bar or a big screwdriver between them as a crank turning lever.
