0 members (), 123 guests, and 8 robots.
Topics128,186
Posts1,057,211
Members48,465
Junior Member
Junior Member
Going to drop my rear 5 inches will i need to do anything with the panhard bar? I see where some sites offer a different length for dropping but i wasn't sure if you needed it or not.
3B Offline
Hy badriand, If you set the truck up to its new ride height you will see how much you will have to modify your panhard bar, as a general rule, the longer the bar the less it moves the axle side to side, hope that helps.
Junior Member
Junior Member
Thanks 3B
