1 members (Thomaslb),
138
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | I'm having trouble opening up the pictures with my 'ol slow dail-up, but it sounds like you have broken the tabs on the steering column "Jacket". I broke 1 or 2 on my '66 GMC. At the time (late 70's) I bought a new jacket from GM. It was a pain to change, but it went along. Today, besides most likey not being able to get a new one, I would consider just changing the whole column. I never had to try it, but you should be able to leave the steering shaft in place when changing it. I would also change the bottom bushing while it's out if you see any wear on it and you may want to also change the small bearing that you have mentioned too.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Dec 2008 Posts: 40 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 40 | I think we're talking about the same thing. I'm just a little leary of putting in a new column because I have to deal with all of the mess associated that comes with having a 3 speed on the column--but it might come down to that.
Trey Wilkins -------- 1950 Chevrolet 3100 Five Window1954 Chevrolet 4100 Dumptruck (Sold)1957 Chevrolet 6400 Dumptruck1966 Chevrolet K20 Longbed Fleetside1966 Chevrolet C60 Grain Truck (Sold)In the Stovebolt GalleryMore pix on Photobucket | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | You need a new mast jacket and the top & bottom bearing, which are replaceable without removing the steering column shaft from the steering gear box at the rag joint. If you still need these items, shot me a PM and I can get you put back together with some good, used parts. Tony Smith [email protected] | | | | | Joined: Nov 2011 Posts: 2 New Guy | | New Guy Joined: Nov 2011 Posts: 2 | I have the same problem in my '64 K10. Two of the tabs have broken off, bearings are both shot, turn signal lever still works when it isnt hanging down and jabbing me in the leg. I have obtained a replacement tube and new top and bottom bearings. My question is, How is the lower bearing installed? does it slide down the column from the top? seems like a tight fit, but I don't see any other way to get it in place. I still haven't removed the pieces of the old lower bearing from the shaft yet either. Any suggestions? mast tube is out, shaft is still connected to the steering box in the truck. thanks, Steve | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The lower brg. comes on from the bottom. Part of the old one is usually frozen to the shaft. You have to heat it or cut it to get it off. The bearing is supposed to float on the shaft with the spring forceing it up to take up the slack. You will have to buff or emery the shaft so the bearing will slide on it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2011 Posts: 2 New Guy | | New Guy Joined: Nov 2011 Posts: 2 | how does the shaft come apart above the rag joint? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Should be a pinch bolt & splines. There are some variations through the years so I might be wrong. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I rebuilt my column and in doing so discovered the steering shaft was nearly cut in half due to the lower bearing failing. With Tony Smiths guidance, in both advice and good used parts, I was able to rebuild the column. At the time I did a how to in regards to removing the column. Check out post #25 of my build thread: http://talk.classicparts.com/showthread.php?t=13928&page=2
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The rag joint flange on the 4-5-6 Chevy trucks is welded to the steering column shaft, so the lower and upper bearing must be installed from the top.
P.S. - Thanks John. I am glad I could help. | | | | | Joined: Jan 2007 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 93 | Trey: I made up two new tabs from the one that was exisiting out of 16 guage metal, then mig welded them back on to where the two were broken. The nice thing is that I could do it inside the truck without taking the whole column apart. Regards, Steve New Orleans
