1 members (dt235sd),
101
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Today I removed the gas tank from my 56 Chevy. The sending unit was so badly corroded it was like a fossil. There was tons of loose stuff rattling around inside, including the pickup screen for the sending unit. I washed it out with water to get as much loose stuff out as I could. I also rattled a chain around in there for a while. Almost all of the loose stuff is now out. I'll go back at it tomorrw. I plan to clean it with muriatic acid, neutralize with baking soda and water, then use Red-Kote. As you may know from my earlier threads, the old gasoline in this truck really varnished up badly. I rebuilt the carb today after having the parts soaking in solvent for several days. I also pulled the manifolds because the intake was full of thick varnish like old maple syrup. I have that soaking now. I'm running all new fuel lines as well.
1956 Chevy 3200
| | | | | Joined: Oct 2006 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 99 | I cleaned my 56 gmc tank out 10 years ago- what a job! I used a a lot of 1" stone, probably same effect as chain. The acid flushing is probably toxic waste, what with all those years of lead. I remember it took a lot of muscleing the tank around.
Well, my time went so quickly, I went lickety-splitly Out to my ol' 55. As I pulled away slowly, Feelin' so holy, God knows, I was feelin' alive..... Tom Waits, Ol' 55
| | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | When I have any fuel tank needing a clean out I take it to a local Industrial Radiator Shop who uses a dip process to clean it and then after it dries pours in a preservative and turns the tank over to assure coverage of all the side wall surfaces. It is the best way for me and so far, no problems. Normbc9 | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I've decided to do the same. I just don't feel like messing with it.
1956 Chevy 3200
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Ahh, here's what I've done. Take out the tank remove the send unit, put in a hundred or two hundred drywall screws. Then attatch the tank to something that turns slow, like the wheel on your tractor, go for a slow drive. I sadly don't have a tractor, so I've do it by jacking up the back of my one ton, and letting it idle in low with the tank strapped to the wheel.
I'm too-cheap to pay. I'm also too cheap to line a tank, unless it has pinholes. Even then, I'd probably just use seal-all for the pinholes. | | |
