2 members (MNSmith, Lostbuthaulinass), 105 guests, and 1 robot.
Topics128,057
Posts1,055,814
#795522 11/06/2011 1:29 AM
i have a fifty chevy 1/2 ton with a nova rearend and a stock straight axle in front with mono leaf springs. i need some info on putting 17 inch wheels on this truck.i have four wheels and tires off of a 94 corvette.there is no way the saw blade wheels will work.the tires will with the right back spaceing .any input would be greatly appreciated.i need to use these tires before they start cracking. i was hoping someone had some advise or an opinion.
tabragg #795919 11/07/2011 7:24 PM
You can get spacer plates that would move the wheel out a bit. How much room do you need ?
1940 Chevy KC 1/2-Ton
Britcon #797267 11/12/2011 3:57 PM
Tabragg, I am running 17 inch wheels on my '53 with stock axles. The wheels are 10 inches wide with no offset (backspaceing). I don't know what the width of a 94 Corvette wheels is. My tires are 265/70r17s so your tires would set your truck lower and give you more clearance. As long as the Nova rear is the same width as the stock rear this same size wheel should work. I have had my truck off road in some rough stuff and had no clearance issues.
Now if I could find a stock looking steel wheel in A 17X10, I would run shorter tires and a dropped axle.
Check my photobucket link for pix.
