1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 126 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 126 | Does anyone know if there are any one piece wheels to fit a 1946 1.5 or 2 ton truck. 6.5 x 20 front 7x20 rear Bolt pattern??? | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy CAJUN CRAW FISH, if you go to the tech tips, at the top of the page, then scroll down to the "Big Bolt' area, the last item there is a very comprehensive article, hope that helps.
| | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy jimmyporter, I'm afraid those wheels are not even close, they are an eight hole mount, and we require a ten stud mount system. I'm very suspect of wheels dimensioned in metric units, I know there must be some intersections but I'm not sure how to convert them to imperial dimensions. I believe the widest Accuride wheels that will fit these vehicles are 6.75", hope that helps. | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy guys, the Accuride part number for the wheels that fit these trucks, stud wise is 28160, which is 22.5" X 6.75". The older trucks had a smaller center hole, and seeing as these wheels are "hub piloted" you will probably have to have a spacer made up by a machine shop to make up the difference for the larger bore of this wheel, hope that helps. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Are you sure, or did you mean to say 19.5"? I'm unaware of a current or any accuride wheel with the 10 lug on 7.25" circle and 22.5" diameter rim.
Again, check the big bolt wheel and tire tech tip for details and ideas, also about those adapter bushings to use newer wheels on old hubs.
Grigg | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy Grigg and guys, Grigg you are correct, my mistake Accuride p/n 28160 is ten stud on 8.75" bolt circle, thanks for catching my mistake. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 1 mm. = .03937" next time you have to make the conversion.
