| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79526 07/03/2007 4:09 PM | Joined: Feb 2007 Posts: 13 Junior Member | | Junior Member Joined: Feb 2007 Posts: 13 | Is there such an adapter to use a mechanical adapter to my 53 gmc speedo on an electronic T5? | | |
#79527 07/03/2007 6:01 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yes, I do believe someone sells a box that takes the signal from the electronic pickup and then with an electric motor of some sort turns the cable going to the original spedo, but they are quite expensive if I remember correctly.
I think you can find the parts to convert your T5 to mechanical cheaper and more reliably than you can get the magic box. | | |
#79528 07/03/2007 6:05 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Try: www.abbott-tach.com www.terf.com They are two of the most popular vendors. The cable-x boxes run around $300.00. Dave | | |
#79529 07/04/2007 5:05 AM | Joined: Feb 2007 Posts: 13 Junior Member | | Junior Member Joined: Feb 2007 Posts: 13 | thanks for the links,I will pull the tail housing off and have a look,I have another trans from a S10 with mechanical drive,but this trans has better gearing plus it is a world class trans | | |
