10 members (MickeyP, 32Fordpuchoptop, Steelonsteel, Hotrod Lincoln, DennisM, Tronman, JW51, Otto Skorzeny, Charles in CA, 1 invisible), 104 guests, and 3 robots.
Topics128,042
Posts1,055,505
Members48,424
#79526 07/03/2007 4:09 PM
Junior Member
Junior Member
Is there such an adapter to use a mechanical adapter to my 53 gmc speedo on an electronic T5?
#79527 07/03/2007 6:01 PM
Yes, I do believe someone sells a box that takes the signal from the electronic pickup and then with an electric motor of some sort turns the cable going to the original spedo, but they are quite expensive if I remember correctly.
I think you can find the parts to convert your T5 to mechanical cheaper and more reliably than you can get the magic box.
1952 Chevrolet 3800 pickup
---All pictures---
#79528 07/03/2007 6:05 PM
Try:
www.abbott-tach.com
www.terf.com
They are two of the most popular vendors. The cable-x boxes run around $300.00.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#79529 07/04/2007 5:05 AM
Junior Member
Junior Member
thanks for the links,I will pull the tail housing off and have a look,I have another trans from a S10 with mechanical drive,but this trans has better gearing plus it is a world class trans
