0 members (), 162 guests, and 4 robots.
Topics128,089
Posts1,056,441
Members48,443
Does anybody know the correct spacing for the clips on the 60-63 GMC stainless steel custom window trim? This is the trim that goes completely around the driver and passenger side windows on the doors. I believe that there are 4 clips lower and 5 for the sides and top, just dont know the correct spacing for drilling and mounting. I can get pics of the trim if anybody needs it.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
k10 Offline
I had a 63 door, but it's no longer in my possession. I'll see if i can take a look at it later on this week. The 60 and 61 doors did not have the trim in the same configuration. I'm sure that '63 did. And I THINK that 62 was the same as 63. You may get a quicker answer on Jolly's site, if you can deal with the antiquated software.
ok, thanks. I just got the trim, but it wasn't originally on my truck, so I just want to mount it correct. I have the trim pieces, but Im not sure on placement or spacing.
Anybody else have a GM with the factory window trim? Goes around the driver and pass side window glass?
