2 members (49nut, Otto Skorzeny), 84 guests, and 4 robots.
Topics128,087
Posts1,056,337
Members48,442
52 1/2 T Chevy Frame with a 55 235 engine. Before taking the truck down to the bolts, the engine was held in place, well, hell - I dont know how it stayed there. It looks like I need to find a different sort of cross member or perhaps do some mod but I would really appreciate the wisdom of you folks on how I might proceed. The existing cross member has been butchered a little and is too narrow for the engine mount bottoms to fit underneath.
Here are some photos:
http://s518.photobucket.com/albums/...uck%20Frame%20Rear%20Engine%20Conundrum/
Is there an A-dapter kit, cross-member replacement, or bubba technique? Thanks!
The problem isn't really the crossmember. The problem is the bellhousing. You have a bellhousing for a '55 Second series. The frame mounting is on a different angle than the earlier AD trucks. You'll need a bellhousing from a '47-'53 Advance Design truck.
Bill Burmeister
Aha. That makes sense but where oh where to find a bell housing? Short of finding one, is there a way to modify what I have?
also, I prefer to not break it all down again to get that bell housing out unless it is unsafe.
Put an add in the parts wanted section for a bellhousing. Easiest fix has been outlined above.
Swap the bell housing, as others have said
•1952 Chevrolet 3800 pickup
---All pictures---
Yep,that's a 1954 and up bell housing,make sure you also purchase the rear mounts .Call Jim Carter if you can't find the bell housing.
Tim
1951 3100 Chevrolet
I have an extra bellhousing with the motor mounts on it. You pay the shipping and you can have it. I think the mounts are still on it. I'm in riverside ca.
