9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop), 105 guests, and 2 robots.
Topics128,048
Posts1,055,626
#793954 10/31/2011 3:53 PM
I got a 1948 Suburban with the clam shell. Im trying to remove the locking handle from the lift gate. I think its lock if that makes a difference. Im trying to get it out but it stuck on or something. Is there a trick to getting it out?
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
It's probably seized. There are four screws on the inside that remove the mechanism from the lift gate. The handle itself has a nut on the back of it on the inside on the lift gate that needs to be removed as well, then it should slide out from the mechanism. My handle is seized solid in the latch mechanism currently, but i've been soaking it periodically in hopes on getting it out and re-keyed here soon.
So you say with that nut off it sould slide out? My nut is off but wont give. I will try soaking it too.
Hello Gents, Any luck removing rear door handle from upper door? I had same issue but soaking & slight hammering didnt work. What did was adding heat to interior side latching mechanism where its held on by a single nut. This broke the rust loose to pull the handle out.
Photos Added ~ http://photobucket.com/upperdoor
1948 3100
1948 Fleetline Areo
1951 Suburban Carryall ( http://photobucket.com/51Burb )
1957 3100
" Tell me who U Hang with & I'll Tell U who You are "!
Good info an pics thanks
Stovebolt CHEVROLET
1949 Chevrolet Suburban
Non stovebolt CHEVROLET
1958 Impala Convertible
1963 Impala Convertible
MY 1949 SUBURBAN
I am bringing up an old post, because I finally got to mine to see how to take it out. It did not come out easily. After hitting the shaft with a nut attached, we had to heat the inner shaft and pull at the same time. It wasn't easy with the heat either!
The handle locked you should not prohibit you from removing it. There is a pin that comes out in the locked position that stops the handle from turning, but you should be able to manipulate it through slot in the hole. You may have to remove the four bolts first to let it slip through the hole. If that doesn't work, I think that the latch should come out without the handle, either way, you should be able to remove the handle in the locked position.
(After thinking this through, it would be a hassle to remove a locked stuck handle. The pin would be at a vertical angle and the slotted hole is at a horizontal angle. Trying to pound the shaft out without damaging the sheet metal lid would be next to impossible. You will have about a 1/4 inch to pound before it hits the sheet metal, twisting the latch may help, but I am not sure how much it will turn in order to be lined up with the slot.)
Be careful when tapping on the threads, even with a nut on them, I managed to do slight damage. I was able to repair mine, but I would hate to see you go through all of the work taking it out just to have more work to do.
Now to a locksmith to get a key made.
