8 members (Nick in Manitou, tclederman, papas52, Robert Crandall, MikeStone1953, Gray_Ghost, Grizzly 34s, 66flea),
65
Mod | | | Forums66 Topics128,159 Posts1,056,901 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 32 New Guy | | New Guy Joined: Aug 2011 Posts: 32 | Does anyone have any experience or suggestions as to which jet to use in a Rochester dual one barrel carb set-up? I don't know yet if they are the same but if I have to change one out is there a better jet that I should put in both while I"m at it?
Thanks, OUP
"when I grow up - please go ahead and dig my grave!"
| | | | | Joined: Feb 2004 Posts: 29,852 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | It really won't matter what jet you use- - - - -dual Rochesters for a 235 flow far too much air for the majority of throttle opening positions, so you'll have lean spots just off-idle no matter how rich you try to jet the carbs. Find a couple of Carter carbs for a 216, and re-position the mounting studs for the narrower spacing. You'll be much more likely to have acceptable low speed and midrange performance, and little, if any loss of high-RPM horsepower. Jerry
