5 members (Otto Skorzeny, Gray_Ghost, Bill Hanlon, fonz8261, klhansen), 83 guests, and 2 robots.
Topics128,060
Posts1,055,833
#792179 10/25/2011 10:37 PM
Okay here is a stupid question. On my '37 one of the hood pieces is forming a crack. Is there any way to get ahead of this before is cracks all the way?
Also I have other folds and cracks that are quite brittle is there a way to soften or relax the metal?
Thanks for any advice you can provide>
Eric
Ex Hall Monitor
Ex Hall Monitor
Stop drill it. What causes it to propagate is the stress riser at the end of the crack. Drill a hole at the end of the crack to eliminate the stress riser. Stress Riser
Stop Drilling
What Richard says Eric. And then you can weld up the crack.
To anneal the metal you can heat it to a cherry red and hold it there for a few minutes then let it cool down slowly in still air, would also help if you could cover it with a high temp blanket so it cooled down slowly.
Of course if your dealing with a sheet metal hood panel chances are heating it is going to distort or warp it. You may just be dealing with fatigue cracks which doesn't mean the metal is hard. The metal would have to have been hammerd a lot to get it to work harden, in which case again, you could anneal it.
Denny Graham
Sanwi
Denny G
Sandwich, IL
Thanks for the help. There is some good information there. This should help me get ahead of this thing.
You're right Eric,good info from the guys, thankfully my trucks PO had the foresight to stop drill a couple of cracks on my fender lips and it does work.
I also use a similar technique on laminated glass windshields.
More pix on Flickr.
