4 members (Bills54, Nick in Manitou, Bill Hanlon, Stovebolt48), 73 guests, and 2 robots.
Topics128,035
Posts1,055,559
#792724 10/27/2011 2:23 PM
So, I think my answer is obvious but I want to confirm or disprove my suspicions.
Are the tail lamps on the AD pickups grounded thru the brackets and into the body?
I am replacing the brackets on mine and I had to cut the bolts. It got too dark to work so I ziptied the old brackets back to the stake pockets thru the original holes and now they don't work at all. Haven't had time to experiment yet as its been raining.
Ex Hall Monitor
Ex Hall Monitor
The ground is through the housing into the body.
Tiny #792776 10/27/2011 5:56 PM
Cool, thanks! That's what I thought. So, I'll need to toss a set of bolts thru to complete the circuit. should I sand the brackets where the bolts pass thru at the housing and the stake pocket?
Ex Hall Monitor
Ex Hall Monitor
There's always a bit of a compromise in exposing metal to the environment to get a good ground when doing so promotes rust that kills the ground. I've had pretty good luck using star lock washers to provide a good ground.
Tiny #792799 10/27/2011 7:33 PM
So you're just using the star washers against the painted metal and letting them dig in?
BLUEMEANIE #792847 10/27/2011 10:05 PM
Ex Hall Monitor
Ex Hall Monitor
That's what I do and it's worked well so far. There are times I have to scrape a bit of paint, you just need to play it by ear. If the star washers work for your application that is the way I'd go if it were me. If they don't work you'll have to scrape some paint.
Tiny #792854 10/27/2011 10:21 PM
Cool. Thanks for the input. Much appreciated!
Grounds on your Bolt are like money, you can't have too many.
~Jim
Call me paranoid, but when I ran my new harness, I ran everything to one of three ground buses. One by the radiator, one in the cab, and one at the rear end. All three are connected by heavy gauge wire that connects back to the battery. Seemed easy enough and read too many posts of people with grounding problems.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
^ Yeah. I was considering going the same route when I rewire everything.
Ground is your friend and when you have plenty of 'em life is good. The current from the battery needs the same good path going back to the battery as it had when it leaves the battery. Anything you do that blocks or slows down that path will upset the electrical gods who will immediately let you know that you did wrong...
I added a ground wire in the lamp housing, and grounded to the frame....just to be sure!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
