4 members (2-Ton, Bill Hanlon, 2 invisible),
90
Mod | | | Forums66 Topics128,142 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79264 06/27/2007 1:43 AM | Joined: Jun 2007 Posts: 95 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 95 | I cannot perform proper lifter/valve adjustment because one of the rocker arm adjusting nut/screw assembly is shot on my '54 235. Apparantly, she ran a long time with it loose (No. 1 exhaust), and the threads are worn smooth.....hard part to find ? sold with rocker arm....???? any help appreciated.
J.D. Jordan
#79265 06/27/2007 2:02 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | A used one is probably the easiest to find. | | |
#79266 06/27/2007 2:02 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | post in the parts wanted section of the swap meet. I am sure one will pop up. | | |
#79267 06/27/2007 2:33 AM | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | | | |
#79268 06/27/2007 5:19 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The Filling Station has them in stock. | | |
