8 members (TUTS 59, 55shaker, moparguy, KEVINSKI, Otto Skorzeny, Lostbuthaulinass, 32Fordpuchoptop, 1 invisible),
103
Mod | | | Forums66 Topics128,141 Posts1,056,487 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | For those of you who've rebuilt your heater control valve, did you use copper spray gasket as shown at the bottom of pages 7 and 8 of this excellent Ranco H16 Control Valve Rebuild Guide?I've seen the photographs a couple of members have posted, but nowhere did they discuss this spray gasket. Comments appreciated. Bill
Last edited by TxLaTx; 10/25/2011 12:14 AM. Reason: Edited link. When I tried to open it, I came to the Packard homepage. If it happens to you, scroll to bottom to last techtip.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Permatex High Temperature Copper Gasket Sealer is really meant to aid in heat transfer as in a head gasket rather than just using a plain gasket sealer which would insulate to some degree. I see no reason why it or any gasket sealer would be necessary in the Ranco valve unless there was a lot of corrosion at its seat, in which case I would look for another valve. But if you feel you needed a gasket sealer I would think that Permatex #2 would be just as good or maybe even one of the silicone gasket makers. Also mentioned in the article is lubricating with Lubriplate. That's a lithium grease and tends to dry out in a few years. I would use a conventional lubricant such as chassis grease or oil which ever is appropriate. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Thanks for weighing in, Denny.
Lithium grease? No way. I already tried that on my HCV, and now I get the not-so-fun job of cleaning the gunk out.
I'm going to hit the staked ring with some Permatex #2 for insurance.
One observation: my plunger doesn't have near enough travel to seal off the flow between tubes. The only way I'd have enough travel is if the valve stem goes all the way into the tube without the diaphragm installed.
I have it back together again. My plunger closes the flow to about half. Seems weird. I risk ripping the diaphragm if I want it to close more.
What does the screw on the rocker adjust?
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | These Ranco valves are not known as the best shut off valve ever made. I don't think they really did a whole bunch of controlling of the temperature and I don't think they actually did shut the water flow off completely. I think they were really meant to roughly control the temperature and in the warmer weather when you didn’t need the heat you could use the inline shut off valve to kill the flow to the heater core.
Alvin completely unsoldered one of these a while back and can tell you just how good of a seal the valve made. I’ve never taken one down to that level but I did notice that mine didn’t seem to close off the flow all the way either.
DG
| | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Thanks, Denny.
Any idea what that adjustment screw (on the rocker, under the thermo-coil) does? When I crank it in, the cable operated arm gets tight, so I loosened it. Seems arbitrary. What does it do?
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sorry Bill, been a few years since I messed with those so I don't really remember but I'm sure it would be some sort of ballance adjustmet so that the valve is closed when it need to be and open when its set for heat. Maybe someone with some first hand knowlage will jump in and set us straight. DG
| | | | | Joined: Mar 2009 Posts: 14 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 14 | I recently repaired the leaking valve in my daughter's truck. I didn't use any sort of sealant - just put it back together like it came apart. It worked great for 57 years, so I figure it's good for a few more. The whole job only took a couple hours.
Mike
1953 3600 350/700R4
