1 members (UtahYork),
215
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 39 'Bolter | | 'Bolter Joined: Feb 2002 Posts: 39 | I forgot........on the 235 for '55 which way is off on this? When the weight is horizontal or vertical? Thanks,Scott | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Viewing from front:
Horizontal(approx. parallel to ground)= heat on. 45 degree counterclockwise rotation(spring tension should provide resistance when cold)= heat off.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Any idea on how to fix one on a 63 w/integral head. My stays in the vertical position, so truck stays cold in nature until reaches norm operating temp. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You are far more fortunate than most who have them stick in the heat on position and constantly cook their carburetors. I intentionally stuck mine in the counter clockwise heat off position and use the choke.
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Thats what I've been doing. Trucks a lil cold natured until she reaches norm operating temp, then she does fine.
| | | | | Joined: Jan 2011 Posts: 35 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 35 | Is there any good reason to disable the valve so that they are always allowing heat to flow? The PO of my truck must have removed the flap from the butterfly.
Thanks, Steve | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | No valid reason I know of unless he enjoyed cooking his carb and having hot start issues.
| | | | | Joined: Jan 2011 Posts: 35 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 35 | Thanks, but since the valve is gone, all the heat would escape through the exhaust so overheating shouldn't result. I guess the downside would just be no preheating in cold weather.
Steve | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Thanks, but since the valve is gone, all the heat would escape through the exhaust so overheating shouldn't result. I guess the downside would just be no preheating in cold weather.
Steve Not exactly. With the flapper missing exhaust will be allowed to go up and over the intake runners and down the other side possibly resulting in a permanent too hot condition. This was discussed recently on the HAMB and the suggestion over there of using a pc. of sheet steel shaped like the gasket and placed between the manifolds may keep heat down and improve performance.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Good catch Curt. I didn't see that. He'll most likely experience percolation/hard hot start issues without fixing the problem.
| | | | | Joined: Jan 2011 Posts: 35 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 35 | Guys,
Wow- I think I'm having a brain meltdown. Doesn't a closed flapper force the hot exhaust up to warm the carb and intake manifold (by not allowing it to go through the exhaust pipe) whereas an open (or missing) flapper would allow the exhaust to escape through the exhaust pipe normally and therefore not heat up the intake manifold and carb? Sorry if I'm just being numb!
Steve
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Here's a section view from the shop manual: http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0604.htmWith the flapper completly removed exhaust can go up into the heat box unrestricted. IMO a properly functioning setup is worth obtaining for the cold start driveability it provides.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jan 2011 Posts: 35 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 35 | Curt,
Thanks. Now I get it, my heat riser valve is in between the exhaust manifold and the exhaust pipe (1958 Apache with 283) whereas you're referencing an earlier set-up that's higher up in the exhaust manifold.
Sorry for the confusion!
Steve | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The initial post was about a 235. Since you didn't say it was for a later V8 we all assumed you were referring to the same engine. See how giving complete information can eliminate confusion.
| | | | | Joined: Jan 2011 Posts: 35 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 35 | | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Hi guys, my flapper is stuck in what I believe is the partially open position. I've hit the weight with a hammer and some PB Blaster to free up the rust but no luck so far. Is this something that I NEED to fix or will it be fine? I've yet to start the motor, but I'm in the process of prepping the motor now. I'd like to keep the exhaust manifold on the motor if possible.Thanks | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Keep working at it. Some heat from a torch can help. Tap it back and forth over and over and over. It'll eventually loosen up. Don't put much twisting force on the weight unless you want to replace the tiny pin that holds it on. You might end up having to split the manifolds and access it that way too.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I just put fentons on my truck mostly so the exhaust shop would know where to put the pipes in preparation for my new engine. I am running with no intake heat at all (hey its only temporary) AND its getting cold out around here. and it runs better that it has for a long time. go figure... | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Tiny, I took your advice and it worked! My heat valve is working great now! After removing it from the block, it took about a week of PB Blaster and hammering and some time with a mini torch. Now it moves really easily. I can't believe how locked up it was. Thanks again. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I'm happy it worked for you.
