Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
8 members (Bill Hanlon, Waveski, Jon G, Pre '68 Dave, 3B, kades51, 2 invisible), 126 guests, and 3 robots.
Topics128,283
Posts1,058,513
Members48,490
#791386 10/23/2011 3:20 AM
I
I Offline
I have a 60 Apache 1/2 ton and need to replace the doors.
What years will fit and are the doors the same on all size models (1.5 ton, etc.)?
InMy40s
All cabs Chevy or GMC from 1960 thru 1963 and from series 10 thru series 70 were interchangable.
and that means everything associated with them,to wit,
windshields,doors,seats,in cab gas tanks.sheetmetal panels,etc.
The only one a little off was the series 50 trucks,or better known as a LCF or low cab foward.
In other words,a door from a C60 will bolt onto a C10 like you have.
A door off of a C50 LCF will work also but the foward edge,bottom corner,will be cut off on about a 45 degree angle to allow for fender clearance.
hope this helps.
regards,
steve sr.
Althougt interchangeable, the tranny hump cover in the medium-duty and the heavy-duty models are flatter. Also, there is a horizontal stiffener through the opening in the floor, with embossed areas on the tranny hump cover, to attach to the stiffener weld nuts.
