| | | Forums66 Topics128,162 Posts1,057,059 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 62 New Guy | | New Guy Joined: Aug 2011 Posts: 62 | My generator is labeled "12 volts", but as far as I'm aware it's still setup for 6v?
Is there a way I can see if it is or is not a 6v system anymore? :-S | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Streamylc, what year truck are we talking about? Six volt tags have a black background, twelve volt tags have a red background. I don't think any twelve volt generators have the brush cover strap on them, hope that helps. | | | | | Joined: Aug 2011 Posts: 62 New Guy | | New Guy Joined: Aug 2011 Posts: 62 | Hy Streamylc, what year truck are we talking about? Six volt tags have a black background, twelve volt tags have a red background. I don't think any twelve volt generators have the brush cover strap on them, hope that helps. Oops. I'm sorry :-P '57 Chevy 4400. Yup, mine is red background with white lettering. I assume this means the system HAS to be 12v right? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Streamylc, yes your truck was twelve volts when it left the factory, here in Canada Chevy trucks were twelve volt starting with the 55 "B" or second series. | | | | | Joined: Aug 2011 Posts: 62 New Guy | | New Guy Joined: Aug 2011 Posts: 62 | Hy Streamylc, yes your truck was twelve volts when it left the factory, here in Canada Chevy trucks were twelve volt starting with the 55 "B" or second series. I'm SOOOO glad to hear this *pffew* I was afraid a previous owner did a "backyard job" on all the wiring to make it 12v. Since I took it out before I determined which it was, I was afraid I was in for QUITE the job re-wiring ;-P | | |
