1 members (Hotrod Lincoln), 49 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#790626 10/20/2011 7:27 PM
Hello,
I am looking for the timing mark on a 1937 216 motor. I believe I have found the window with the pointer in it and have spun the flywheel around and around. I have not seen a steel ball or arrow or even a line.
Would someone be willing to take a picture of the mark lined up or in the window so that I can see the what and where of this mark?
Any advice would be greatly appreciated.
Eric
EricJ #790636 10/20/2011 7:50 PM
Riding in the Passing Lane
The best way is to get under the truck & remove the flyweel cover. Turn the engine till you find the marks. Clean the area around it & paint a white line on it. Then it will be real obvious when it passes the hole.
1972 Chevy c10 Cheyenne Super
Ex Hall Monitor
Ex Hall Monitor
The ball is only the size of a BB so it's easy to miss if you've not seen it before.
Tiny #790687 10/20/2011 10:26 PM
To find TDC watch the #6 hole valves as you turn the engine (by hand, using the fan- belt, plugs out). When #6 intake rocker pushes down, start slowing down and paying close attention. When it starts coming back up, and the #6 Exhaust rocker just starts pushing down, #6 is in valve over-lap. Since #6 is the sympathetic cylinder to #1, #1 is about to fire. Go very slow, and watch for the TDC mark on the flywheel.
(Firing order, 1-5-3-6-2-4: When #1 is about to fire, #6 is in overlap; When #5 is about to fire, #2 is about to fire; and when #3 is about to fire, #4 is in overlap)
Once you find the bb and put some White Out on it. Then look for the triangle and put a ^ mark on it. I also marked the needle with a blue grease pen so I wasn't straining to see both.
Its easy to cruise past it if you're using a hand crank or wrench on the crank pulley. It takes forever if you use the fan. We used the hand crank while watching the valves and as we got close, we'd switch to the fan.
Tiny #790691 10/20/2011 10:44 PM
...DG photo...
...painted ball. My pic...
...video...
DG photo is a 216
My photo is 235
Both trucks are 1950. Not your year truck but should give you an idea what to look for
DADS50 #790712 10/20/2011 11:51 PM
Thanks for the help. I really appreciate it.
EricJ #790816 10/21/2011 11:27 AM
May I also mention the BB is quite small
Ex Hall Monitor
Ex Hall Monitor
An FYI, you don't need to find TDC just to locate the ball. It goes around every time the engine turns. I pulled the plugs and used the fan to turn the engine, finding it in no time. A wipe with a thinner rag and a dollop of white paint, problem solved.
