6 members (1955 1 Series, 2-Ton, Shade Baby, 46 Texaco, dt235sd, 1 invisible), 346 guests, and 6 robots.
Topics128,162
Posts1,057,056
Members48,463
Are there any replacement parts available for a 48 gmc rocker panel for a 1 ton. Is there supose to be rubber flap between the rocker panel and the running board and is there a replacement for that too?
Bruce,
1947-1955 panel body cab to running board seal (for 1/2 ton - 1-ton would be longer - I assume such a seal was also used on a 1-ton?). Whatever seal was used on a Chevrolet would also have been used on a 1-ton.
I do not know of specific "rocker panel" parts for panel-body trucks (unless Ray Stanley makes them); however, people have reported that the bottom outer door skin-panel can be used on panel-body trucks' rear-body "rocker panel".
Thanks Tim
