| | | Forums66 Topics128,192 Posts1,057,350 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 5 New Guy | | New Guy Joined: Dec 2008 Posts: 5 | In the midst of restoring my grandfathers '48 I've replaced almost every wear item on the rear suspension (it's a well-used farm truck). During the final going over I noticed the Rear Spring Seat section in the shop manual http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0461.htmMy bushings are starting to break up with age but it doesn't seem like anyone sells replacements. Does anyone know where to buy new rubber bushings or if there's a substitute part lurking out there? | | | | | Joined: Aug 2011 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 30 | Did you look at LMC? They have pretty much everything you'd need to build the truck from scratch. For a hard to find part thats where I'd go.
------------------------- 1950 Chevrolet 3100 5 window Original 216ci and SM420 4-speed
| | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | I have some NOS steel bushings. $3 each. Let me know the size (width) and if it has a hole in the center or not. Send and email to [email protected] with an address and I'll get a ship cost. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Personal buying and selling should be done in email message or in a Private Message.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Here is a possible source. Axle/Spring Mount Bushing . According to the Master Parts book, they used the same U bolts here for Pass from 38 to 53 and all 1/2 Ton from 47 to 53. I am guessing that maybe the bushings were the same. I am interested in this search too for my 38 Master. | | |
