0 members (),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78944 06/19/2007 11:17 PM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | I was thinking about adding a oil filter to my motor....I have noticed on other guys pictures that some use the beehive or alternate set up....I have a 235 out of a 57..
Next question good place to buy one. | | |
#78946 06/20/2007 4:20 AM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | napa makes a remote oil filter kit...use the search feature..the kit number is listed.. | | |
#78947 06/20/2007 5:05 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just a suggestion.....I'd check my oil pressure on your 57 engine before you add the by-pass filter system. I found that the bypass system bled of 5-7 psi of oil pressure and it didn't seem feasible to divert pressure from the mains to pump 10-15% of the oil through a 1950's technology filter. Granted, the 235's don't make/need a tremendous amount of oil pressure but if an engine was in the latter stages of it's life, the extra 5-7 psi might be needed. Changing oil at 2000-3000k seems easier than changing out a set of engine bearings.
If you're running good oil pressure without the filter and can afford the accompanying pressure drop, you could add it on. Your call!!!
Dave | | |
#78948 06/21/2007 2:38 AM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | I recently bought a rebuilt 235...it has great oil pressure....so then maybe I will just change the oil 2-3 thousands miles instead of adding a filter....less work
thanks guys | | |
#78949 06/21/2007 2:16 PM | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | There's your answer Change the oil every 2000 miles and use shells rottella oil as discussed here before it seems to work!!!!!!! | | |
#78950 06/22/2007 3:02 AM | Joined: Jun 2001 Posts: 11 Junior Member | | Junior Member Joined: Jun 2001 Posts: 11 | if you use the NAPA filter adapter, and the correct restricted flow filter, you can have a spin on oil filter and maintain good oil pressure in your 235.
Then change your oil every 2000 miles. | | |
