4 members (greenie-reddy, Bill Hanlon, Steelonsteel, 1 invisible), 62 guests, and 2 robots.
Topics128,208
Posts1,057,448
Members48,471
hello all, thanks for all your help - i'm learning more and more each day!
I would like to make my '51 1-ton FB more of a "driver" and not so much a work truck and wanted to know where to start?
I'm assuming I'll have to change the gear-ratio in the rear end but don't know where to begin and how to even tell what the current ratio is.
Any help on this would be most appreciated!
514 if it's stock,if you have the Eaton rear,you can change out the center section with a 3/4 and get a 457 gear.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
Thanks Floyd! Here is a picture of the rear housing and the serial # on the side - a link to these pix, not sure if that'll help. It is stock, 100%
Rear End and Serial #
I am not an expert on these, but if the rear end will accept the 1967-1972 eaton 3/4 rear differential/pumpkin, you should be able to install 4;11 gears. Here's the same rear end that Denny had and I think he changed his out to the 4:11 from the 67/72 3/4 or 1 ton truck.
Originally Posted by GMONIZ
AXLE IDENTIFICATION
denny graham how-to photo's
This information should be helpful to those that are looking for the eatons.
From Bill: (Longbox55):
There will be a code stamped on the front face of the carrier. I've posted the codes before, but for sake of saving a ton of searching for them, here they are again.
1967; HW, JU. These are listed as 4.11, may be Spicer rather than Eaton
1968; NA, NB, WI, RN (RN is listed as a 1 ton diff)
1969; NA, NB, OT, OW, OY, TF. There are also 1 ton listings; IE, LJ, LZ, MR, NZ, RN.
1970; TAA, THU, THW, TJU, TLN, TMZ, TNA, TNB, TOT, TTF, TWI.
1 ton; TIE, TIH, TLJ, TLX, TLZ, TMR, TNZ,TRN.
4x4 K20; TPW, TPX
1971; TAH, TAJ, TJA,TJB, TJP, TJS, 2G.
1 ton; TAK, TAL, TAP, TJK, TPZ.
4x4; TJH, TJJ,TKB, TKC, TKK, TKL, TKS, TKT.
1972; RAH, RAJ, RJA, RJB, RKK, RKL, RKS, RKT, RJP, RJS, RKB, RKC.
1 ton; RAK, RAL, RAK, RAP, RJK.
4x4; RJH, RJJ.
I do have listings for a 3.54 ('71 and '72) and a 4.11 ('67-'72). but from what I understand, those are Spicer differentials rather than Eaton, though I have seen a '72 with a 3.54 code on an Eaton differential.
BTW, most, if not all, GMC trucks from the '60s used a Spicer differential in the rear, either a Spicer 60 or 70 (I've seen them both ways).
_________________________
I installed a 71 3/4 rearend gearset in my 1951 1 Ton. It has very tall 16" tires and the engine turns at 2700 rpm at 60 mph. The ratio of the new set is 4.10. I am happy with this and most of my higher speed driving is done at 50 mph but I occasionally go 60 without any problems.
1951 1 Ton Completed
Does anybody know anything about the G87 power-lok rear diff. option that was available in say a '71 3/4 ton? Would this gear set bolt into my "52 3600?
Terry
'52 Chevy 3600
'03 Chevy 2500HD
'64 Pontiac Grand Prix
'93 Jeep Wrangler
From what i see the 1967-1972 chevy and gmc trucks had Eaton or Dana rearends , i found myself online for sale a 1967 chevy one ton truck the GVW on the Vin plate is 10,000 lbs the wheel base is 133 inch , im thinking the rear grearing is 514 but i was thinking about 411 or 457 , i want to be able to go on the highway with a trailer at 65 or 70 not at 45 or 50 , how hard is it to change a rearend grearing,chuck , there is a 67-72 chevy&gmc one ton truck its wheel base is a 147 inch the GVW for that is 14,000 lbs rearend grearing is 617
Sorry mess up at the end i ment to say. there is a 67-72 chevy&gmc one ton truck its wheel base is a 157 inch the GVW for that is 14,000 lbs rearend grearing is 617
Crusing in the Passing Lane
Up to '72 or so, 3/4 and 1 ton w/ automatic trans had higher ratios, 3.73?
1 Offline
Doc, From your picture it is a "Eaton" rear(round rear cover) and if stock it is a 5:14 ratio.36 ring gear teeth,7 pinion gear teeth. You should be looking for a third member,Pumpkin/ Gearset from a 1967thru 1972 chevy/GMC 3/4 ton or 1 ton with auto tranny. The gear set will bolt right into your axel housing. It will have 37 ring gear teeth and 9 pinion gear teeth. If you request, I can send a pic of the ring /pinion part number. I have it somewhere in my Pic file. Good luck with your search for this pumpkin. I sold one back in march,2011 for $350.00 plus $130 shipping and have seen them advertised at $450. Jerry.
Gotta chime in here.
My truck is a '59 Apache 3600 - 3/4 ton - that came with 4:56 gears in the Eaton rear end. I wanted a truly highway capable truck, so I ended up swapping out the entire rear end for a Dana 60 rear from an '87 Dodge 2500. I got 3:54 gears, so the truck can run on the highway all day and not break a sweat. Pretty much a bolt-in operation except for modifying the spring perches. The Dana is about 3" wider than the Eaton, but the tires still clear the fenders with no problems.
Worth considering.
Chris
Moderated by  Dusty53
