1 members (Guitplayer), 104 guests, and 2 robots.
Topics128,149
Posts1,056,818
Members48,456
Does anyone know for sure if a 1955 1st series 1/2 ton rear end is any different than a 1955 2nd series 1/2 ton rear end? Thanks.
Stovebolts are good for the heart
That was the year that they went to an open driveline in both series. I can't imagine they made a 1/2 year only set up. It should be a 3:90 ratio or possibly a 4:10 if it had an OD. The 55 1'st series that I have seen look the same as my 56.
Fred
The 2 trucks have different spring configrations, so the spring perches will be in different locations.
I haven't found anything to be different in the 3rd members.
Thanks for the information.
so the 3rd member is the same on both rear ends ?
I'm almost certain that is correct.
