1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#78877 06/17/2007 12:11 PM
Hey guys,
I am getting to the point of thinking about pulling my engine and having it overhauled, it smokes a bit and needs it. Anyway because of the babbit bearing I don't want to take it just anyplace. Do you guys have any recomendations? I am in Ohio and am willing to travel out of state for a good mechanic if needed.
Thanks in advance
Ed
#78878 06/17/2007 2:23 PM
Riding in the Passing Lane
Jaspers
1972 Chevy c10 Cheyenne Super
#78880 06/18/2007 2:49 AM
H Online: Content
If it's a babbit-pounder, it's going to take more experience and expertise than the average volume rebuilder will be able, or willing to supply. I'd strongly reccomend going for the machining process to install the insert bearings in the rods. I was in charge of doing that machining on Chevy rods for a big rebuilder in Nashville, and it makes it much simpler to do a good buildup.
Adjusting the oil squirters is also a critical part of a good rebuild. They're not only tasked with filling the dipper troughs, but they need to squirt oil directly into the rod dippers at higher engine speeds. If possible, you'll need to find someone who is familiar with the special needs of these engines, and give him enough time to build it the right way.
#78881 06/18/2007 12:32 PM
Hotrod,
Thats pretty much on track to what I was thinking, I want to stay away from the NAPA types that do mass rebuilds as they don't have the knowledge toc do babbits. I would like to find a mechanic and machine shop all rolled into one so they can do they upgrades as well as overhaul while I am working on the rest of the truck. I expect it will take a bit of time for them to do this and as I said I will travel across state lines to find a good shop if needed.
Thanks to all that have responded so far.
Ed
