| | | Forums66 Topics128,047 Posts1,055,662 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78877 06/17/2007 12:11 PM | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Hey guys,
I am getting to the point of thinking about pulling my engine and having it overhauled, it smokes a bit and needs it. Anyway because of the babbit bearing I don't want to take it just anyplace. Do you guys have any recomendations? I am in Ohio and am willing to travel out of state for a good mechanic if needed.
Thanks in advance
Ed | | |
#78878 06/17/2007 2:23 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#78880 06/18/2007 2:49 AM | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | If it's a babbit-pounder, it's going to take more experience and expertise than the average volume rebuilder will be able, or willing to supply. I'd strongly reccomend going for the machining process to install the insert bearings in the rods. I was in charge of doing that machining on Chevy rods for a big rebuilder in Nashville, and it makes it much simpler to do a good buildup.
Adjusting the oil squirters is also a critical part of a good rebuild. They're not only tasked with filling the dipper troughs, but they need to squirt oil directly into the rod dippers at higher engine speeds. If possible, you'll need to find someone who is familiar with the special needs of these engines, and give him enough time to build it the right way. Jerry
#78881 06/18/2007 12:32 PM | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Hotrod, Thats pretty much on track to what I was thinking, I want to stay away from the NAPA types that do mass rebuilds as they don't have the knowledge toc do babbits. I would like to find a mechanic and machine shop all rolled into one so they can do they upgrades as well as overhaul while I am working on the rest of the truck. I expect it will take a bit of time for them to do this and as I said I will travel across state lines to find a good shop if needed.
Thanks to all that have responded so far.
Ed | | |
