3 members (panic, baldeagle, 68ironhead), 81 guests, and 4 robots.
Topics128,014
Posts1,055,330
Members48,419
#776804 08/31/2011 6:26 PM
I installed rebuild kits on 1950 chevy 1/2 ton brake cyl. and master cyl. Used old cap on mc and air and fuild ooze out of tiny hole in the top of cap. Any help would be appeciated.
I don't know what stage you are at but if you have it too full, it coukd be a problem. Also the MC linkage should be adjusted as per the manual.
1951 1 Ton Completed
I'll try taking some fuild out,still confused on reason for a hole in the top of the cap.Wouldn't it let air in?
yes it lets air in, to allow fluid movement in and out of the MC - the level should be slightly below what the inside of the cap would touch, not filled to the rim - also, you may find the system hasn't had the air fully bled out and that air is pushing back against the fluid in the MC .... the exposure to ambient air is the drawback of the old simple systems, the fluid will slowly absorb moisture, so should be flushed and changed occasionally
squeeze #777522 09/02/2011 10:47 PM
Thanks Bill, I'll give it a try
I am going to rebuild my brake system and would like to flush the brake lines. What should I use to do the flush? Do I just run brake fluid through the lines, or is there a brake system cleaner?
Riding in the Passing Lane
You can flush them with alcohol but time you bleed them you will get all the old fluid out.
1972 Chevy c10 Cheyenne Super
