3 members (Bill Hanlon, 59 fleet, klhansen), 117 guests, and 2 robots.
Topics128,182
Posts1,057,260
Members48,467
I am in the process of installing a T5 in my 55 2nd with the original 235. I am trying to figure out what to use for a pressure plate as the original is not reusable. What will bolt to the stock flywheel 3705410 which has 6 mounting holes for the pressure plate?
1955 Chevy 3100
3B Offline
Hy hb32, what size is the pressure plate? I think the disc/input shaft is finer than the ten spline that was on the original transmission. The six bolt pressure plates all share the same bolt pattern, provided they are the same type and size, I assume you want a diaphragm style pressure plate.
if your running a 10 3/4 original flywheel and presure plate you can run a 11 inch clutch from a 86 astro van v6 if your trans is 14 spline
1949 SUBURBAN
Thanks for the help and managed to find a 10 1/2 that bolted in along with a Camaro V6 disc. I will see how they work and move up to the Astro set up if I have issues. 14 spline is correct.
1955 Chevy 3100
