1 members (Otto Skorzeny),
81
Mod | | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78820 06/15/2007 5:05 AM | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Guys, Need some advice on what to do in what order on rebuilding the stock front end of my 57 1/2 ton.
I have brackets on order from Buffalo Enterprises to convert to 6 lug disc, so I will be also adding a power booster under the floor and running all new lines. Still not sure what to do with bearings, convert to taper rolle or stick with the original or but new original style. The truck is probably never going to go more than 50 miles in a day.
I am planning to replace the original tie rod ends, any need to also replace the rod?
What else should I do when I am 'down there' in the front end? Eventually thinking of power steering, but that can wait... | | |
#78821 06/15/2007 10:07 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Every conversion kit says to change to the roller bearings. I believe I would. There is no need to replace the tie rod unless it is bent or the threads are messed up. Check the king-pins. If you change to power steering you will change the steering gear & drag link so don,t bother with them unless they are real bad. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#78822 06/18/2007 2:57 AM | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | So Roller Bearings and tie rod ends are all I need to worry about?
Anyone know where to get quality roller bearings, as I cannot find anyone that is not suppling off-shore manufactures of unknown name or specifications. | | |
#78823 06/18/2007 5:28 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
