4 members (Jon G, MRMEROTH11, Peggy M, Southerntruck), 124 guests, and 0 robots.
Topics128,068
Posts1,055,880
Members48,428
#788033 10/12/2011 1:05 AM
My original sending unit was very rusty (but still worked) and cork floats were in bad shape. I have removed the rust by soaking in vinegar. After cleaning unit up, I have an ohm reading of 6 at bottom of float bar travel and 36 at top of travel. Reading will climb as bar is raised. Does this sound right?
It should range between 0 ohms and 30 ohms.
Check the strap from the underside of the stud to the bottom part of the unit. It likely has some resistance (6 ohms) in one of the connections.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
