0 members (), 186 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
How can I remove rust from inside fluid chamber
before I replace with rebuild kit?
Barry
Barry, I'd just use solvent & a stiff bristled parts washing brush & blow it out with an air gun, same as anything else.
Doug
I wouldn't even try, you will never keep the stuff you didn't clean off from breaking loose and contaminating the cylinder.
Paint & Body Shop moderator
Anonymous
Unregistered
Anonymous
Unregistered
Try electrolysis it'll get rid of that rust. ZooKeeper
I can't help but think solvent etc. will leave a residual amount of rust in there.
I wonder if anyone has made a rotisserie that will spin parts like gas tanks and this master cyl. with abrasives inside in order to clean them out?
~Jim
If the master is that bad go with a rebuilt,,don,t put your prize and you at risk for a few bucks saved...doc
I used lacquer thinner and it did not remove the rust in the tank reservoir.
Just cleaned all the grease & brake fluid off.
I did read somewhere where it was better to use Alcohol to clean brake components.Why is this and do I need to reclean parts with Alcohol?
What about media blasting?
Thanks, for all comments.
Barry
http://i189.photobucket.com/albums/z24/focus2002_2007/100_1317.jpg
http://i189.photobucket.com/albums/z24/focus2002_2007/100_1316.jpg
I
I Offline
Throw it away and buy a new one. I would even take the chance of some little spec of crud plugging the holes instead of a single acting master, leaving you with no brakes at all
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
If the bore is heavily pitted you need to replace it or have it sleeved.
To remove rust on items like these, degrease and remove the scale from the part, then dunk it in a bucket of vinegar for a while. Check it every so often and hit it with scotchbrite. Vinegar will remove all corrosion and not remove paint. When it is done rinse it completely and coat the exposed surfaces with crisco or "red rubber grease". Nether is petroleum based and can then be cleaned with beake cleaner without fear.
