1 members (UtahYork),
108
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 12 New Guy | | New Guy Joined: Oct 2007 Posts: 12 | Hi All,
I just installed new window channel rubber and the inner and outer 'wipers' in the door of my 68. Now the window is exceptionally hard to roll up and down. I did not know how to get to everything in the door so at one point I had the regulator completely unbolted. There was a bang when the last bolt came out. Now I'm wondering if the spring somehow came off the regulator. I never did figure out how to get the window glass and regulator completely out of the door so I haven't been able to do a visual inspection. If anyone has any ideas on this I would greatly appreciate it.
40 chevy 1.5 ton, 50 chevy 3/4 ton, 67 chevy stepside 1/2 ton, 67 C50, 68 C50, 73 chevy 4x4 3/4 ton, 2004 Silverado 1/2 ton , 2005 HD 3/4 4x4 Duramax (don't even get me started about my Oldsmobiles!)
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | It's not the same, but similar till someone else comes along you might try here 59 Chev resto page I think there is a removal procedure in it.
| | | | | Joined: Oct 2007 Posts: 12 New Guy | | New Guy Joined: Oct 2007 Posts: 12 | It turned out to be worn-out/sprung window regulators. Put in new ones from LMC at 39.00 each and they go up and down easier than I thought possible. Now nice and tight, no rattles and easy up - easy down!
| | | | | Joined: Oct 2007 Posts: 12 New Guy | | New Guy Joined: Oct 2007 Posts: 12 | One last note on this, the October 2011 issue of Custom Classic Trucks magazine has an article on replacing door weatherstrip/rubber in the 67 to 72 Chevys. At some point I believe they will publish the article on line.
I hope someone finds this helpful.
