1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 12 New Guy | | New Guy Joined: Aug 2007 Posts: 12 | Hi There I just scored a 51 one ton and Im thinking the motor has been swaped Here's the stamped on numbers off the right side of the motor D424027E54y .Any thoughts on this will be appeciated. Thanks , Morris | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Your suspicions are correct. What you have is a 235 from a '54 Passenger car, originally used with a Powerglide transmission.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 12 New Guy | | New Guy Joined: Aug 2007 Posts: 12 | | | |
