4 members (baldeagle, 2-Ton, Stovebolt48, 1 invisible), 84 guests, and 4 robots.
Topics128,014
Posts1,055,332
Members48,419
#78736 06/12/2007 10:52 PM
i have a 52 chevy pu with mustang II front end with power rack and pinion steering. does anyone know which headers will give me clearence to run my steering shaft? i am running a 350
#78737 06/13/2007 11:10 AM
We kinda need to know what engine you have.
Every 25 years I like to rebuild that 292 just for GP
#78738 06/14/2007 5:44 AM
I assume your engine is a sbc with side mounts. Most any block huggers will work. It probably won't be a straight shot, you will need to use some universial joints.
~Jim
#78739 06/14/2007 4:13 PM
Junior Member
Junior Member
' Offline
I would recomend rams horns manifolds. No hassle with leaks and if you can get some from a vette they breath really well and look real nice. You also will have all the clearance you could need. Mine looks great with the rams horns and it still has pleanty of power.
Evan
