Upper lift gate & hinges, upper lift gate keepers, lower end gate, lower end gate pivots, lower end gate hinges and mounting hardware. The jambs are manufactured to receive either style at the factory, with the proper parts for the conversion. Plastic plugs & rubber stops indicate the alternate configuration mounting locations.
