| | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | I have talked with a couple of older rodders at some car shows about doing a column shift conversion to run a four speed muncie manual trans. Im told that with the three speed coloumn r-1, 2-3, would become 1-2, 3-4 and a small shift lever on the floor for reverse. I keep hearing its been done, but cannot find any actual pics of this conversion. Any thoughts on it? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I've seen pics of it being done with a cable for reverse. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The Corvair 95 trucks and vans had a 4 speed column shift from the factory.
Bill Burmeister | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Do you know what year the 4 speed column shifts were used? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
