1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 13 New Guy | | New Guy Joined: Sep 2009 Posts: 13 | My 58 has a 76 nova differential non posi. It is not installed while doing a frame up resto. Here is my dumb question, if I turn the pinion while holding the drive hub I can keep the hub from turning, is this correct? It will turn if I let go. Seems like only one side should be able to do this. Thanks for your help. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy rrenner, in a standard differential, if you turn the pinion then you can only hold one wheel, the other will spin. | | |
