0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 21 | My sending unit no longer works. Should I buy used or new? What would you recommend and from who? 1960 Suburban the tanks in the rear with the spare tire unit below. If this doesn't belong here let me know where so I can relist in the proper place. Thanks | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | i have a spare old unit, did you check the wiring and ground first? i can check to se iff the resistance changes on mine. not much available for burbs. you would have to use your old pieces and install my resistance unit on your because my float piece is shot. | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | check to see if the float has a hole in it. if you need a sending unit i have one for a 65 suburban minus the float | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | http://www.rockvalleyantiqueautoparts.com/catalog.htmRock Valley is an excellent source for universal senders for various ohm ratings. And also for gas tanks. Nice little company. I have a 0-30 ohm from them for my 6 volt truck and it's working great. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | http://www.rockvalleyantiqueautoparts.com/catalog.htmRock Valley is an excellent source for universal senders for various ohm ratings. And also for gas tanks. Nice little company. I have a 0-30 ohm from them for my 6 volt truck and it's working great. | | | | | Joined: Oct 2007 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 21 | I believe I have enough info. Thanks to all that responded. | | |
